Can anybody tell me why (head bearing grease)
I know many softail owners use wheel bearing grease to lubricate the head bearings on their softails becase it doesn't get runny in the warm weather. But looking at the 2013 Harley parts and accessories catalog it indicates that wheel bearing grease can be used for head bearing for all bikes except 97 and later softails and dynas. For 97 or later softails and dynas it indicates to only use Harley special purpose grease for 97 and later softails and dynas. Why is this? what is the difference in the head bearings in the 97 or later softails and dynas as compared to the other models?
What negative affects will using wheel bearing grease for a softail or dyna head bearing have?
Why does Harley say to not use wheel bearing grease for the head bearings in 97 and up dynas and softails?
its the same with oils, its a marketing plow,,, Harley does not make Filters, Oil, Spark plugs, Battery's, Gease, And most other things,, Screamin eagle parts are made by other vendors, just rebadged,,
Automotive wheel bearing grease ( wheel bearings) does your car suffer from melting bearing grease from the heat off your stub axles/brakeing?????..SO how can it melt in your head stem that has no heat cycles like your hubs in your car,,, SIMPLE answer is it aint going too happen it has a high melting point..??? basic mechanics really.
