Question on Samson Exhaust
With the special shift linkage that they sent with my Cholo's there is 1/4" clearance between the linkage and the inner primary WITHOUT the chrome cover.
Hope this helps.
Might call Sampson direct and ask them.
Hope this helps.
My heat shield is so close to my inner primary chrome cover that its probably touching it. Ive been running it all summer with no problems though so I don't think its an issue.
Samsom TD's seem to fit a little different from kit to kit and bike to bike. You will be able to tweak things around a very small amount so hopefully for you it will be enough for your setup.
Others with a clearance issue to the chrome inner primary have dremeled a small notch in it...you cant see it under the pipe, no biggie. Much better than going without IMO
