softail switch housings
RE: softail switch housings
It's easy, you just need to be patient with the Ferrules at the end of the Throttle and Idle cables. Everything fits tightly in the housing so you also need to be mindful of where the wires and pull-ties go. And don't forget to use a shim between the brake light switch and brake lever before disassembling housing.
Pretty easy job.Make sure you squeeze your brake lever and wedge it in that position so it doesn't break the brake switch.Loosen the throttle and idle cables.I just did each half at a timetaking note ofthe routing of the wires.Another thing to watch for is that little wedge on the end of the thumb screw.Make sure it's in the proper position for re assembly.
thanks guys, unortunately i didnt get a chance to give it a try yet. and its to late to do it now, 20 to 9 here. i'll do it tomorrow after work or after i take my cat nat after work. i'll let you all know how it went.
but hey, this was a gift from my wife, so she must still love me LOL
NO S##T!...I changed my grips and swapped my switch covers out to chrome (left the housings stock) and while I was doing the throttle side I dropped one of those ferrules...spent a half hour looking for it! [:@]
ORIGINAL: PhantomMaxx
