Blackline Handlebar Ideas
Exactamundo. They're adapters/inserts for the trees since the factory FXS trees are indexed for the split bar setup to hold them in place. So yes, come up flush with the top of the tree so you can use standard risers. I used L.A. Chopper's adapters. Move the speedo and you can use any bar you want as long as the center section is wide enough.
So I ordered some like this today.
John at Hardtail has been super cool answering all my questions. He said they should ship by the end of next week. I know they are probably the most common style, but I wanted something different, and love the shape of these. Just wondering how they will look in a Blackline application with the built in risers wider apart. Stay tuned.
Hi 24v,
New"ish" member here from Vancouver Canada - Have been a member for awhile, but for some reason I cannot find a way to send you a private message like I have been able to on other forums.. Guess because I have not posted enough - not sure..
I know you've moved on to the breakout, but wanted to see if I could ask you a few quick questions on your blackline and the vinyl wrap you did to the upper forks..
Did you drop the forks to install or just do a cut and install while on the bike ? I have the same bike except Vivid black and I noticed you went gloss black wrap - I was thinking matte because the triple trees are matte, but after seeing your picture the gloss looks good in the pictures..
I appreciate the help - your blackline and breakout are customized perfectly
Rob
Rob
Originally Posted by Chevis
Tried the vinyl.. looks good, but decided to get aluminum pipe cut / powder coated to to slide over.. will update with a pic once installed
The aluminum pipe is a more robust method. Keep in mind that PVC pipe works just as well. You can get spray paint for plastic at Lowes or Home Depot. The plastic pipe might be safer for your tubes.
Love the Blackline by the way.
