Stage 1 Air Cleaner Cover - Effects on Performance??
Sorry if this has been discussed before, but how much influence does the air cleaner cover have on overall performance? I just installed a screaming eagle stage 1 round air cleaner on my bike. Along with it, I ordered a HD Bobber Style Round cover. It is a bit larger than I expected and covers the entire open air element on the air cleaner. It has an opening on the bottom to let air in, but I wonder just how much it would. I've had this type of air cleaner on a previous bike and ran it with just a small round trim piece covering only the front face of the element leaving the actual element completely exposed to the air.
I'd hate to use the bobber cover and undo the effects of going to the stage 1 air cleaner.
Anyone have any input/thoughts?
Thanks!
Thanks!
I'd hate to disagree but somebodies got to. I switched to a SE stage one air filter and bought a similar cover and like you decided it was to big looking. After putting my hand near the small slit air intake and feeling minimal air flow I switched to a derby style cover and have to say after putting my hand near the filter again noticed a high amount of air being sucked into the engine. After a ride I definitely noticed the bike had more pep to it and felt like it was breathing better.
If you are running a stage 1 backplate with only the chrome cover, then there should be no issue with the volume of air that gets into the engine. The only issue I can see with that cover vs a more open filter would be the temperature of the air going in. That big metal cover is sure to heatsoak and increase the temperature of the air going by it. Whereas without the cover the cooler air can go straight into the filter.
The hotter the air, the less oxygen. Less oxygen = less power.
