Anyone installed Custom Dynamics Load Equalizer on their Crossbones?
Update: It all fit... The Signal Equalizer and the Triple Play Module. I had to grind away some of my battery cover gussets (under the cover where you would never see) to install one module on top of the battery. I shoulda took a photo...perhaps another day.
BTW - To program the rear turn signal brightness on my Triple Play Module, I had to turn Switch #2 On-Off-On first...and then turn Switch #1 On-Off-On...backwards from the instructions. I post this just in case anyone else ever comes across this.
Pretty stoked...these LED's are damn bright!
Just put fronts on mine a couple weeks ago- wow, what a difference. I was going to post that the wires seem to be long enough to go behind the oil tank on the fender extension. When I add the brake light controller, I guess I'll find out cuz I'm out of room under the seat. Thanks for the tip on the controller, nice to know.
Sorry guys. Just seeing this post. I have an 09' Crossbones and I was able to fit both the Signal Equalizer and the Triple Play Module under the frame cover. It's a tight fit but it works and I've had no problem <knock on wood>. The difference between the LED's and the stock bulbs is like night and day (plus it looks cool).
03Custom883
07-30-2014 05:44 AM
