Alloy art led marker light question
Old 06-11-2013, 12:02 PM
fatboy1729's Avatar
fatboy1729
fatboy1729 is offline
Question Alloy art led marker light question
Just replaced my front and rear turn signals with Alloy Art led's. The rear was no problem to wire up. The front however is mind boggling. The stock front turn signal wiring has 3 wires and the new led's have 2 wires. I was told that if I purchased the Custom Dynamics Eclipze2 Module, the fronts will stay running and also work the turn signals. Still only works the signals and NOT running lights. What am I missing? Thanks for any help on this...
Old 06-11-2013, 02:48 PM
knightenforcer's Avatar
knightenforcer
knightenforcer is offline
That sucks, I have the Eclipze2 ordered and supposed to get it this week.
Have you contacted Custom Dynamics yet?
As per their website it would turn single filament to dual, meaning running and turnsignals. The catch is that only up to 300ma each side. Not sure how much those alloy art leds put up. Also are you running any load equalizers? reason i asked, is that on my bike, the LED tailight and front leds wont function properly without the load equalizer.
Old 06-11-2013, 03:58 PM
fatboy1729's Avatar
fatboy1729
Thanks Knightenforcer for replying. Yes I contacted Custom Dynamics and did everything they wanted me to do. Still no luck. Now I just noticed that my tail light is not on now. It just lights up when the brake pedal is depressed. Why did I even go with Led's. These Alloy Art Led's are very expensive and a PIA to hook up. Never had a problem with the stock signals...
Old 06-12-2013, 11:20 AM
fatboy1729's Avatar
fatboy1729
Thanks John (Knightenforcer) for all your advice. I retraced everything I did and come to find out it was a blown fuse. My bad. I should of checked the fuse in the first place. Everything works perfect now. No load equalizers, just the Custom Dynamics Eclipze2 Modules in the front, one on each side...Thanks again for all the help. I really appreciate it...Ray...
Old 06-12-2013, 11:32 AM
knightenforcer
Glad things worked out
Ride safe,
John
medicmike
13
07-25-2017 06:16 AM
Scooter68
04-03-2015 11:56 AM
LeatherWolf
Electrical/Lighting/Alarm
11-22-2014 07:16 AM
UltraDune
04-13-2014 07:42 PM
rerb95
08-25-2008 09:26 PM
Quick Reply: Alloy art led marker light question
