01 Deuce 200 tire?
Old 06-11-2013, 07:29 AM
Half-Fast Deuce's Avatar
Half-Fast Deuce
Half-Fast Deuce is offline
Default 01 Deuce 200 tire?
What factory parts from the later model Deuce do I need to install a 200 on mine? Any part numbers would be awesome.
Old 06-11-2013, 10:34 AM
Village Idiot™'s Avatar
Village Idiot™
Village Idiot™ is offline
The later model Deuce only had a 160 on it like the earlier ones. To get a 200 on mine, I put a 17x6 wheel off a Softail custom on it. This requires shaving and grinding on the swing arm and caliper along with either machining the stock pulley or purchasing and installing a thinner pulley and belt. You’ll have to use spacers to align everything. You’ll also have to shave the inner fender supports are these will rub if you ever lower it.
Old 06-11-2013, 11:10 AM
Half-Fast Deuce
I thought the later models had a thinner belt which allowed for a 200 to fit.
Old 06-11-2013, 05:07 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
They do. You can do a wider wheel with a thinner belt (20MM) and belt pulley. I think a 17x6.25 will be pushing it width wise. We designed a kit that utilizes an 18x5.5 for this.
Check out the Deuce 200 tire kit.
http://www.hogpro.com/showcat2.php?catid=11
Old 06-11-2013, 06:13 PM
Village Idiot™
That's right, forgot about the 18x5.5. That extra clearance means all the difference. OP would probably still want to think about shaving the inner fender supports so he doesn't rub if he ever bottoms out. I don't know that he would though unless he lowered the bike. Mine would be horrendous if I didn't do that. I'm running a 2" collar kit.
cruiser73
12-27-2020 06:33 PM
bigdaddyeo
05-13-2018 10:36 AM
muttboy
01-16-2017 03:56 PM
rgm
04-27-2014 07:27 PM
DeuceRyder
05-19-2008 02:53 PM
Quick Reply: 01 Deuce 200 tire?
