Extended rear fender lowered question.
Old 06-04-2013, 01:35 PM
BklynBound's Avatar
BklynBound
BklynBound is offline
Default Extended rear fender lowered question.
I own a 04 fatboy, and have lowered the rear with a progressive lowering kit as much as i can, but I see that there is a ton of space between the top of the tire and the rear fender.
I seen a ton of pictures of rear fenders lowered a lot closer to the tire, and was wondering has anyone had this done to their bikes, did they re-drill the fender? buy a custom fender?
I've been checking out the Klock Werks extended rear fender, but before I pull the trigger on it I want to know if I can lower the fender closer to the tire first, if I can then my stock fender might look pretty good that way.
Any info as well as pic's would be much appreciated.
Here is a pic of the bike.
Old 06-04-2013, 02:13 PM
kozy22's Avatar
kozy22
kozy22 is offline
Yours is prob only dropped 2" with progressive, an air shock will drop it to 4"
My wheel is 18" but you get the idea of the look
Old 06-06-2013, 11:01 AM
thaghost's Avatar
thaghost
thaghost is offline
Here is a pic of my bike with the klock werks fender for reference....
Old 06-06-2013, 11:14 AM
"HI"'s Avatar
"HI"
"HI" is offline
Nice Ride Ghost!!!! Have any more pice?
Ditto on the air shock, I think to achieve that "slammed" look an air shock is the best method.
Old 06-11-2013, 12:08 PM
BklynBound's Avatar
BklynBound
Kozy.... I like the air shock, and I'm sure the 18" rear wheel helps give it that lower look as well... thanks for reply.
Thaghost.... Is your bike lowered or is that fender designed to give it that low look? It defiantly looks lowered. I'm also thinking about getting same pipes, they look really low to the ground... do they bottom out a lot or does the picture make them look lower then they really are?
Thanks
Old 06-11-2013, 05:04 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Shotgun shock is usually what people do.
Old 06-11-2013, 05:33 PM
thaghost's Avatar
thaghost
thaghost is offline
I've got the klock werks 4" stretched fender and the shotgun shock. In that pic, it's slammed.
Old 06-11-2013, 05:58 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Someone was making a tucked stretched rear fender (fireman) which i think looked much cleaner. The KW looks great but I liked this even better.
Old 06-13-2013, 05:38 PM
BklynBound's Avatar
BklynBound
Thanks for your feedback guys.... I'm doing a lot of work on my bike and just want to make sure I get everything perfect or as close to perfect as possible.
I'll defiantly be purchasing that KW fender.
Thanks again.
Old 06-13-2013, 07:04 PM
kozy22's Avatar
kozy22
kozy22 is offline
Thanks again.
You'll be better off buying the shotgun over the fender. The slammed look is from the shocks not the fender. The fender is only stretched at the back bottom.
Quick Reply: Extended rear fender lowered question.
