Winter Build Nigh Train 84/200 Paint Scheme
bored .010 over on 95 inch jugs. Ported polished heads, new valve springs 175#
Over 110hp and 110 torque
- Custom Harley Davison Paint Set red w/ ghost flames,1 of 200 made
- Primos 3 inch belt drive open primary
- Exile "sprotor" kit Chain drive
- Thunderheader Exaust
- Performance machine 4 piston front caliper
- Harley Davidson oil cooler
- Fueling oil pump and cam support plate
- Dave Mackey engineering .590 cams
- Bandit racing clutch
- Mikuni 42mm carb
- Ported and polished heads
- Keith Black pistons
- Compression releases
- S+S rockers
- Custom matching Foot pegs, Gas cap, Air cleaner
- Lowering kit
- Leather wrapped levers
- Performance Machine Grips
- Burley 14inch chubby apes
- Drag Bars
- Fat daddy spoke rims
- Mikuni 42mm carb
- S+S rockers
- Lowering kit
- Drag Bars
Comment and a question. Comment= I agree with the one reply to your post that mirrors would look hot flipped upside down but it's also your bike and not mine. Question= With your head work were you able to put domed high compression pistons in it or did you go with flat top pistons? Your bike turned out really nice and I am sure it will run circles around that bike when it was stock.
Who is your insurance with and do you have enough coverage for all that money?!
Most insurance companies only offer a small amount of coverage for Mods so if you haven't added additional coverage up to or just over the amount you have in the bike you might look into it!
BIKE IS BEAUTIFUL by the way.
