Question about Speedo/Tach combo (7090070A/7090072A)
Old 05-11-2013, 04:21 PM
BigMESA's Avatar
BigMESA
BigMESA is offline
Default Question about Speedo/Tach combo (7090070A/7090072A)
I just got mine in and installed it and everything seems to be as advertised but the fuel gauge on the speedo doesn't show anything. I have the HD LED fuel gauge already installed on the bike and I'm curious is it conflicting somehow? Does anyone else have this set up and it works for you?
I'm heading out to fill the tank up and ride for a little bit to see if it has to "calibrate" or something. Thanks in advance.
Old 05-11-2013, 04:50 PM
Warren9073's Avatar
Warren9073
Warren9073 is offline
I don't have the LED speedo but my stock gauge still works.
Old 05-11-2013, 05:19 PM
Bluraven's Avatar
Bluraven
Bluraven is offline
I bet after you fill it up it will calibrate full, then it will work as it supposed to.
Mine shows empty with about 15 miles till I'm walking.
I love mine.
Old 05-11-2013, 05:21 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Mine has the option to turn the fuel gauge off. Did you turn it on?
Old 05-11-2013, 05:23 PM
Echo6 Sierra's Avatar
Echo6 Sierra
Echo6 Sierra is offline
I have the LED gauge as well and have been considering this speedo. Interested on hearing how you make out...
Old 05-11-2013, 05:58 PM
jam436's Avatar
jam436
jam436 is offline
what he said. there's an option to toggle the fuel gauge and/or gear indicators off. I'd check that first.
Old 05-11-2013, 06:26 PM
BigMESA's Avatar
BigMESA
BigMESA is offline
Yea I made sure its on, it displays the gauge but there are no segments to show any fuel level. The gear indicator doesn't work but then again it's not supposed to on a 2006 so I'm not worried about it. I just want to know if this is supposed to be like this with the LED gas gauge or if there's a problem with my speedo and I need to return it.
Old 05-11-2013, 07:08 PM
Vic Bronco's Avatar
Vic Bronco
Vic Bronco is offline
As others have said, it needs to calibrate itself. Give it a few solid fills to see if it starts showing more accurate fuel readings. Your LED gauge shouldn't affect your speedo.
Old 05-11-2013, 08:04 PM
BigMESA's Avatar
BigMESA
BigMESA is offline
I'll ride the hell out of it tomorrow and see what comes of it. Right now it shows as if I'm completely empty but the low fuel light is not on. I'll be sure to follow up with the results.
Old 05-11-2013, 10:06 PM
Dynalmadman's Avatar
Dynalmadman
Dynalmadman is offline
I have the HD led gas gage mod, and I just installed this speedo/tach.
Gas gage tracked exactly with the LEDs from the start. Never required any calibration.
Michael
Quick Reply: Question about Speedo/Tach combo (7090070A/7090072A)
