Lowered with SS , now belt rubbing . mmm.
So guys. the shotgun is much fun to ride with.. I can go on and on .
but when I slam the bike low and want to ride it like that and be cool , I did hear this 'whinning' sound, so I stop and look.. and keep looking.. finally it turned out the belt is rubbing on the primary (right under the oil tank).
I did some google search and found that some people talk about taking a chunk out of primary without effect.
I wonder, how much did you take off ? wouldn't that create a sharp edge, even more dangerous if it rubbed ? Do I have to take the primary inner out ? (that is a major job !).
I can't wait to hear from you all.
My belt rubs a bit too, mostly just on big dips but I'm only 2" lower than stock. Thought it was rubbing the primary, so i was going to grind the opening a bit at the top this past winter. When I had the wheel off and got a good look at it, it wasn't rubbing the primary at all. It's rubbing on the starter jack shaft. Not much you can do but go to a smaller trans pulley. I've put about 5k on it lowered and haven't had any issue, just kinda polishes the top side of the belt. If you're running around slammed, then it will obviously be worse. I haven't heard of any major issue with the belts though, lots of the train guys run around slammed and don't seem to have any problems.
you would think shotgun would maybe mention this?
ive read alot of threads w/ you guys and i dont remember reading belt rubbing issues
of any sort w/ that kit? i have a sas never had any probs after a year or so
not tryin to be negative at all just wonder why, i know you just spent a **** load of time and $$$$ on yer fxst and a belt that rubs is not that great, hope you get a solution as i know u will
I agree with you that most people tend to discuss how great the ride is (which it is, I mean 2" lowered was more comfortable than my 422s were lowered 1.5") the thing is, it is tempting to go lower, you just want to go lower , and now I get the whinning noise..
Will watch the belt and ignore the noise.. but for a minute there I thought the cops were chasing me with this 'awwwwwww.. hawl' LOL
