Custom Chrome..Be Careful!
Old 05-03-2013, 11:11 AM
Bloozmann's Avatar
Bloozmann
Bloozmann is offline
OK..I have an update on this situation...I received a call from JP Cycles who said that the washers are NOT part of the kit, and they have no access to washers to send me that I could use.
The stock bolts that came out of the bearing case had a washer permanently attached to them, so IMO washers should have been provided. Also, the case itself has indentations where the washer should sit. Replacing the stock bolts with the Custom Chrome bolts minus the washers actually makes the bike look worse instead of better. We buy this stuff to make our bikes look better, not worse..
All this could have been avoided if JP Cycle would have actually posted an accurate picture of the bolt kit on it's website instead of a picture of some random bolts with their usual disclaimer of accuracy.. . If I would have seen the actually kit on line showing that the washers weren't included, I never would have purchased the bolt kit in the 1st place.
So to sum this up. Custom Chrome can kiss my behind, and JP Cycle is now on the bubble. Any item that has their common disclaimer of " this may not be the actual item" under it, won't be going into my shopping cart! I just purchased a bunch on Gardner-Westcott hardware from Dennis Kirk. I hear they have an excellent reputation.
Word to the wise people..
Old 05-03-2013, 11:23 AM
atlantaallen's Avatar
atlantaallen
atlantaallen is offline
Dennis Kirk is good but the same thing could have happened with them.
Come on, neither JP, Dennis Kirk, nor any of the other big ones are rip off artist or they wouldn't be as successful as they've been.
When you saw they had no washers, why didn't you just return them, case closed, and shopped with someone else?
Or gone to Ace and bought 8 washers? Couldn't be too expensive. Seems like much ado about nothing that couldn't be cured without all the vitriol and name calling.
Old 05-03-2013, 12:19 PM
Bloozmann's Avatar
Bloozmann
Ace has black chrome washers that are smaller diameter than a regular flat washer?..Tell me which Ace has them and I will get em. I never called JP cycle a rip off artist..I merely said they should do a better job of representing what they sell...And why return a 19 dollar purchase that would cost 6 dollars to do so? No one name called anyone...You make no sense my friend. Next time,try reading the posts before commenting. You're clueless!
Old 05-03-2013, 02:15 PM
atlantaallen
Sorry. You still seem angry. Have a good week end.
rbscooter
05-02-2012 11:47 PM
skulltrainharley
01-14-2012 07:20 AM
ftanner
05-16-2011 04:19 PM
MidnitEvil
05-17-2009 11:10 AM
trackadaptor
02-19-2008 09:57 PM
Quick Reply: Custom Chrome..Be Careful!
