SE Perf Fork Oil Change (Fatty & Sporty) Report
Hello everyone,
I haven't contributed much lately but thought I would put this out. I just did an 06 Fatty and 05 Sporty Custom fork oil change per the specifications in the shop manual. I noted the first few miles that the front end of both stood up more. But after a mile or two things settled down. Handling was vastly improved on both. The thing is, I figured the ride would suffer on bumpy concrete like highway. Actually to my surprise, both bikes are significantly smoother now on otherwise bumpy concrete highway.
Thinking this through a bit, I surmise that this could be that when the forks compress hitting a bump, that they don't compress "too large" making the next bump less of a stiff hit.
I'm sure that was coherent. Anyway, using SE Performance fork oil made a huge difference on two different chassis. The job didn't take long and the old oil was pretty dark grey after 10k Miles on both.
Tip, the handle of a plastic like milk carton (Wal-Mart drinking water) makes for a very nice funnel that reaches past the spring on the sporty. Never saw the spring on the Fatty. In fact both bikes had different procedures for the job. SE Performance Fork Oil - Easy day - Huge ride improvement. Ride Safe!!! Mike
Great post. I recently upgraded the stock fork oil to the Harley Heavy Duty. Like you I was please all around with the improvement. I get that the MOCO puts the lightest oils and sets the shocks on the softest settings from the factory because they want to sell bikes. And the plushest ride probobly helps that happen. But after a while you find its not the best setup. The heavier fork oil really does improve the bikes ride and handleing. I almost chose the S/E like you, but so far the Heavy is working. Next fork oil change, I probably will do the S/E, given your positive comments.
I had very similar positive results also! I changed my front and rear springs to progressive and that alone made a HUGE difference. The SE fork oil seems to make the ride a little firmer but overall much better! Change your front springs...my front end sagged 2 inches with the stock springs...1/4 inch with the new springs...best 100 bucks I spent on the bike.
I think there is something to this, the Performance Fork Oil - Heavy smells a bit like gear oil and not at all like standard motor oil.
The improved ride with only changing fork oil is well worth the time and only costs $10.
