Blinker replacement HELP. And plans for mods.
I have searched up and down these forums and can not find anything I like. I am looking for as small as possible peg mount blinker/running light/brake lights. I have the black line and there is no separate tail light its all in the blinkers. Does anyone have any suggestions? Joker machine has something close but they are only available in chrome, and I am not sure if they could perform all 3 functions. I am also looking for front blinkers same thing as small as possible I like the idea of bar end ones but I already ordered Roland Sands tracker grips and a joker machine hidden bar end mirror, its going to be a POA enough to drill out the left grip to get the mirror to work and that eliminates the ability to use bar end blinkers. I was looking at their fork mount "marker lights" but it said you have to use a load regulator to get those to work as blinkers. Can someone run through that process with me?
Thanks a lot in advance.
Stage one (just ordered last night) for me was an exhaust, new top triple tree to fit new handlebars without loosing the speedo, risers, grips, levers, mirror, and a fork brace for the front and to get rid of the front fender. and hopefully blinkers tonight!
Stage two will be, to lower the bike front and back, new 18 or 19" rear wheel that matches the stock front one new rear fender painted black, new fender struts and a fender mounted license plate bracket with tail light, probably the roland sands one, or similar.
Custom Dynamics!!!!
they have fork wrap arounds for the front... and a turn brake strip thta will tuck under the rear fender...
wraps
http://www.customdynamics.com/truflex_truwraps.htm
tail
http://www.customdynamics.com/integr...light_bars.htm
I am not affiliated with CD....
i have purchased there products, full price.. and believe in them..
wraps
tail
Custom Dynamics!!!!
wraps
tail
wraps
tail
Someone in here just did a brake light strip under the lip of their Blackline in here recently. Looked pretty slick.
Here is one thread:
https://www.google.com/url?sa=t&rct=...E1XmhdscRm-jhQ
Here is one thread:
Here is one thread:
Here is one thread:
Thank You!
