New brakes - fade ?
New brakes - fade ?
Hello again: With the input of many I have my new Lyndall Z-Series pads in the front caliper of my 08 fatboy. I took it out this evening to do a few safety tests and then a few hard stops to see how they perform. Overall the new pads work very well when cold but I am getting brake fade after three hard stops. I did let the brakes cool slightly between stops. They also smelled hot.
Once I get back home I took a look at the the rotor and the center of the rotor contact surface was a different color. It appeared to me that only the center 1/3 of the pads were actually doing the work, almost like they are somewhat rounded. Being new at this I am not sure if this is normal new pads.
So what do you think?
That makes sense. Considering how much energy the pads absorb, and the fact that they last as long as they do, I can see it make take a little time for the new pads to wear in.
One thing I did not do was to spin the wheel to insure that there was no undo brake rubbing. I will do that tonight. The bike pushed just fine.
Brake in
For sure need to break in gently and give them a little time before final judgement. I replaced my front brake with a PM 13" rotor and 6 piston caliper because I felt the braking somewhat lacking after comming from a line of dressers with dual discs that were all upgraded with good stuff. I took it for a ride after assembly and thought, 'boy this was an expensive mistake'. I checked it over and all looked good so kept out on the back roads and took it easy for a few days. After a few hundred miles I was liking it and now after several thousand miles it has become an awesome brake with good feel and control.
Mr. Lucky
04-03-2010 06:27 PM
