low fuel pressure
04-21-2013 | 08:12 PM
Stage II
low fuel pressure
I recently figured out that I have low fuel pressure. I checked the lines, they were okay. I decided to bypass the regulator and see what the pressure was coming from the fuel pump, it read 35psi. Is it common the fuel pump goes bad? Its a 2006 with 34,000 miles.
04-21-2013 | 09:10 PM
I haven't really heard of any issues with the pumps. Could you tell me what your symptoms where? I've been having problems with mine. Thanks, Mike
04-21-2013 | 10:57 PM
Is this on a Sporty or your softail?
04-22-2013 | 08:25 AM
Could be pin holes in the fuel line within the tank. It is common problem and a relatively easy fix.
Common symptoms are hesitation when 1/2 full or less, but problem "fix" themselves when the tank is full.
Huggerbugger
08-01-2018 07:52 PM
Geoff of NV
10-24-2015 02:25 PM
labelkil1s
12-10-2011 06:12 PM
bikersurgeon
06-07-2011 10:38 PM
aris
12-19-2005 02:24 PM
