Rocker c/ Breakout conversion
Yeah, not sure about calling it a Breakout conversion, because I think you've ended up with a nicer looking bike than either the Rocker or the Breakout.
Thanks everybody
Thanks for all the compliments guys!! I really appreciate it. I am very proud of my, for lack of a better word, creation. I chromed this one out but I am now building a black one with the black Breakout wheels and have purchased a new SE 110 to put in it and also the black Breakout front end(wide glide with black lower sliders). I hope it turns out as well as this one did. Maybe I should make up my on model name and sell them. lol
Conversion is almost complete, just have to mount front headlamp. Turned out better than I imagined. I could not have made it look like this without the help of this forum. I put CVO Breakout wide glide front end on my bike(everything above fork sliders), wheels tires, mirrors, and custom painted front Breakout fender. Then chromed out everything I could. Thanks again to all who post on this forum, it has been so much help.
I am wanting to put the regular breakout gasser front wheel on my wide glide, but I want to see if it is even close to possible.
I am looking for 3 measurements.
1) Can you measure the width of the hub on the front wheel (I figure the CVO wheel and regular wheel have the same hub width)?
2) Could you also measure the distance between the forks sliders where the axle goes through (inside left slider to inside right slider)?
3) Could you measure the triple tree width (inside left leg to inside right leg)?
