help with a 21 inch wheel
I just bought a arlen ness rim and avon tire for my 2004 HD low rider FXDLI the problem is I think my fender will hit the tire, what kind of spacers do i need to raise my fender up I have check many web sites and can't find anything that will help, I dont want to buy a new fender if i can help it,,can someone help me with this? Thank you.
what size rim can i go with
should i put a 2.15 rim or the 2.50 rim with the 21 inch tire on my 2004 low rider and will it bolt up to the forks ok, the stock rim size is 2.15. I was told that the 2.15 x 21 inch rim has a max tire size of 90/90/21 but the 2.50 rim can go with the 100/90/21,,, the bottom line is i want the 21 inch tire with the 100/90 tire, will this fit hope some body can help with this ,
The chart I'm gonna post here says 90/90-21 is as big a tire that will fit a 21x2.15 wheel. Your results may vary.
http://api.viglink.com/api/click?for...13665846897505
