2000+ swing arm on a pre 2000 fatboy
Old 04-15-2013, 09:59 AM
MYCRISIS's Avatar
MYCRISIS
MYCRISIS is offline
Default 2000+ swing arm on a pre 2000 fatboy
So I read somewhere you could put a 2000+ swing arm on a pre 2000 softail. (Mines a 97 flstf) and that you could then use up to a 200 rear tire. Anyone know the details for this swap? What else has to be changed? These swing arms can be had for pretty cheap.
I just bought a new Shotgun from JD, will the same unit fit a 2000+ swingarm?
What say ye Softail God's???
Old 01-29-2014, 05:11 PM
peterjamesbenson's Avatar
peterjamesbenson
peterjamesbenson is offline
Well the swingarm alone is not gonna work. u will need a new sprocket and belt also a new fender
Old 01-29-2014, 05:49 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
you can pick up oem parts for cheap. you will have to cut your frame struts and go with bolt on struts so at that time it would be a good idea to pick out a cool fender.
Old 01-29-2014, 08:11 PM
Santo's Avatar
Santo
Santo is offline
I saw a guy on youtube put a 200mm tire on a Slim and there is a guy on this forum that did the opposite on a Crossbones with out swaping the swingarm and just moving the wheel spacers around. Not sure about older Softails.
dochawken
07-09-2021 12:40 PM
joshua_d.williams@yahoo.com
05-03-2017 08:48 AM
Bdobb
06-02-2011 08:55 PM
sportsterxl50
All Other Models
07-14-2008 03:07 PM
rgardjr
08-30-2007 04:24 PM
Quick Reply: 2000+ swing arm on a pre 2000 fatboy
