softail custom headlight question
The only real issue here, that I'm aware of, is physical space. If you can make it fit, with an adaptor, or even some custom mount then it will work.
I had a dual headlight system on my 2000 Softail for years, it mounted with a custom mount that I had fabricated. Then I went to a much larger, custom cross headlight (thing was actually in the shape of a cross, not just the bulb, the entire headlight) which was more of a traditional mount. I didn't worry about maintaining the original headlight plug for either, just cut the wires and hard wired them in.
Electrically, its just wire connections (or a plug if you keep it) and possibly, just possibly mind you, a different fuse if the bigger light draws more power, most likely won't even need that.
itznin
Electrical/Lighting/Alarm
04-29-2017 12:46 PM
