Call a dealer for accurate scoop. I have a set of 2009 spoke smooth laced hd wheels I'll sell ya cheap if the dealer tells ya you can use them.
Rear is 16" and front is 17"
No good. These are non abs and like the other poster said dual disc in the front.
I guess you could remove 1 disc ....pm me if you need me. Good luck with whatever you decide.
The only part of the wheels that has to do with abs system is the bearings correct? So if i got a non abs wheel could i just put abs bearings in it and remove one of the discs and be good to go?
