FXSTB 08 Problems installing a Danny Grey Seat
Old 03-22-2013, 10:44 AM
jamesfr's Avatar
jamesfr
jamesfr is offline
Default FXSTB 08 Problems installing a Danny Grey Seat
Hi,
I have just purchased a Danny Grey buckcrack Solo for my 2008 Nighttrain but having problems fitting it.
The part I have is 0802-0646
Can anyone confirm that this is the correct seat for my bike?
It appears that it wont clear the wiring under the seat?
Any ideas what I am doing wrong??
Attached Thumbnails FXSTB 08 Problems installing a Danny Grey Seat-seat1.jpg   FXSTB 08 Problems installing a Danny Grey Seat-wiring1.jpg
Old 03-22-2013, 10:47 AM
jamesfr's Avatar
jamesfr
jamesfr is offline
I assume the connect blcok you can see nearest is the rear light cluster.. Even if I remove this the seat then lays on the emc connector??
Attached Thumbnails FXSTB 08 Problems installing a Danny Grey Seat-wiring2.jpg
Old 03-22-2013, 01:36 PM
jamesfr's Avatar
jamesfr
jamesfr is offline
Anyone had any similar issues?
Can you mount the fuel pak in a different place instead of under the seat to give any more room?
Old 03-22-2013, 05:18 PM
bill in okc's Avatar
bill in okc
bill in okc is offline
I had my 08 FXSTB's stock seat recovered and it fit something like that when I got it back. I think it was just the new leather was tighter maybe. I don't know if that helps but it was similar.
Old 03-22-2013, 05:23 PM
Mill908's Avatar
Mill908
Mill908 is offline
On my FXSTS 2004 (Softail Springer) I installed a solo Lepara, it was off all winter and I just put it on last year it sat perfet this year it sits up alittl but it is still below zero up here, not too sure why either but you are noT alone.
Old 03-22-2013, 05:48 PM
alcotune's Avatar
alcotune
alcotune is offline
Maybe move your fuelpak below your rear fender (in front of your rear wheel) then you might be able to move around a few wires/ connectors.
Old 03-22-2013, 07:09 PM
jamesfr's Avatar
jamesfr
jamesfr is offline
Do you have any pics?
Do you mean mount it ontop of the ECU?
The seat is definitely resting on the connectors...
Old 03-24-2013, 09:19 AM
jamesfr's Avatar
jamesfr
jamesfr is offline
All sorted!
Moved the fuelPak to above the battery and sat the connector just under the ecu.
Fits but only JUST!
chickenhauler
08-21-2017 03:47 PM
41inWV
08-05-2015 12:39 PM
HarleyGirl69
Touring Parts
08-02-2009 06:01 PM
stglide
09-13-2008 02:47 PM
BIG Y 2014
03-16-2008 07:07 PM
Quick Reply: FXSTB 08 Problems installing a Danny Grey Seat
