Throttle cable replacement
I'm not 100 peraent sure. But I believe there are some clips in there that might snag it, and i don't know if it will scratch the paint. Have you tried tugging on them now to see if they loose enough to pull? You might try it and if it works sweet, if not then your going to have to pull the tank. I'm sure someone more experiance then me will chime in.
Highly unlikely you can make it work. I just swapped mine when I did my build and had the tank off. Pretty close quarters in there, not to mention the clips as creed said. If the cables were straight, I would give you the definite possibility of a firm maybe, but with the 90* bends, don't think so. Taking the tank off isn't a big deal like I thought it was before I had to.
RaceFace
08-04-2012 11:53 PM
