Upgrading Exhaust and Intake..tuner?
I'm getting ready to purchase a full exhaust and stage 1 intake for my '12 Deluxe.
I have heard that a tuner is not necessary, but is reccomended. Does anyone know what should be done for best performance. What tuner would you reccomend, I've been looking at the Dynojet Power Commander V.
Thanks
Thanks
i run a PCV in my 2010 Lo, and i was running one of the 'stock' DynoJet maps downloaded from their site..bike ran good, still had some decel popping.. then i finally had it properly tuned. that's when she opened up and started running like a summmamabitch. literally scared me when i hit the throttle after the tune.. immediate difference.
point is.. whatever fuel tuner you go with (and the PCV is great, but not the only one out there), you'll get the most benefit from getting it properly tuned.
is it required? no, but HD tunes their bikes lean from the dealer, and adding more air and more exhaust while keeping the same fuel will just make it lean-er..so it's recommended to get one so your engine runs the way it should
I would get a tuner. Your bike would benefit from it. One or the other you would be fine without a tuner but with both tuner is a good idea.
I've had a pcv on my dyna, but on my Slim i have a power vision. Only thing is that it marries to the bike, but otherwise you dont have to have it under ur seat and is really user friendly.
If you decide to use a Power Commander or Powervision buy it from Fuelmotousa.com. They are a forum sponsor and will pre load a map for you bike and parts you add. They also offer the best prices a double your warranty. Best customer service around. BTW they are both easy to install yourself.
Newer Bikes, the SERT or the new Power Vision seems to be the way to go.
These Tuners, Flash the ECM instead of being a piggyback system.
IMO these are way safer, no chance of failure. And with a good dyno tune or someone familiar with the software, you gain full potential of your bike.
I rode by bike with intake/pipes for an afternoon before it went for a tune. and after i got it back, was night and day difference
I have experience with several different tuners. If you're looking for a DIY tuner, Harley's SERT or their Pro Race is not the way to go. To achieve full benefits from these devices, a dyno should be utilized. The SERT and the Pro Race do not have the capability to save the base map and it can only be reloaded by a Dealer if necessary. If however you're having your bike tuned by a Dealer or Performance shop, by all means, consider the Harley tuners.
For the home wrench'er, I recommend; Thundermax, Power Vision or the Power Commander. The Thundermax is the more costly of the three but it replaces the stock ECM.
Find a trustworthy Indy who knows his stuff - O.K., you're deeper into the wallet but you won't regret it.
