Blackline Todd's cycle Bars
Old 02-21-2013, 03:14 PM
Kcortez07's Avatar
Kcortez07
Kcortez07 is offline
Default Blackline Todd's cycle Bars
I just ordered Todd's cycles strip bars. And I was wondering if anyone else has these or knows of cable lengths that will work. I've done some searching but haven't seen a definite answer.
I'm replacing all the cables, brake clutch throttle and idle. And recommendations on a vendor for this would be appreciated as well. I've been looking at magnumshielding.com.
Thanks everyone.
Old 02-21-2013, 06:26 PM
cjames235's Avatar
cjames235
cjames235 is offline
You will love them! I have them on mine too they are great.... I'm not sure on the cable lengths though. I went with the magnum BYO, which so far have worked out great!
Old 02-21-2013, 06:45 PM
Kcortez07's Avatar
Kcortez07
Thanks cjames235. The bars look great. Can't wait to install. I'll probably just measure the cable lengths once I mount then order.
Also how was the electrical side for the bars? Any complications wiring them?
Old 02-21-2013, 08:13 PM
frog37_'s Avatar
frog37_
frog37_ is offline
Subscribed. Thinking of ordering these as well.
Old 02-21-2013, 08:34 PM
Kcortez07's Avatar
Kcortez07
Hopefully we can get help on cable lengths.
(It's too cold in Chicago to go mount the the bars)
Old 02-21-2013, 11:20 PM
JDeCo21's Avatar
JDeCo21
JDeCo21 is offline
I have them on my blackline. Best mod ive done, you'll love them. Installed the bars then measured for lengths. Went with +6 all around. Worked great for me. Ive read some guys saying +3 will work but that seemed too tight for my measurements. I think a +5 would be the shortest I would recommend. Also found that for the front brake line using a 90degree banjo at the bars and a 45 degree at the caliper helps route the cables tight to the bars and away from curving out towards the headlight. Had it the opposite way first and my brake line ran right towards the light instead of down the bars and forks, im **** and it looked like **** imo. Good luck
Old 02-22-2013, 06:32 AM
Kcortez07's Avatar
Kcortez07
Thanks jdeco21. I'm pretty **** about all this as well. Thanks a lot I appreciate the info.
Old 02-22-2013, 06:39 AM
cjames235's Avatar
cjames235
Only complication with wiring is getting the wires around the bend. Wasn't too bad, just be patient with it. I moved my turn signals down to the forks, so that was more wiring that had to be pulled through.
Old 02-22-2013, 02:20 PM
Kcortez07's Avatar
Kcortez07
I'm just removing my turn signals all together.
Did you have to remove the tank? Extend the wiring?
Old 02-23-2013, 11:13 AM
goats's Avatar
goats
goats is offline
i like the bars i just wish they came in 14 or 16 inch... the 12 inch just seem a little short for me
Quick Reply: Blackline Todd's cycle Bars
