brake questions? can you mix and match?
The stock Heritage has a four piston caliper in the front and a two piston caliper in the rear.
Since 60% of the braking on a motorcycle is by the front brake, I would use the stock configuration. I'm not saying you should use the stock calipers, I'm saying you should use a four piston caliper in the front and a two piston caliper in the rear.
It all depends on what year forks you have as to what will bolt right up for a decent price. Seeing as the heritage has a single front caliper I recommend a better than stock caliper as well. I run a PM 6 piston caliper on my fatboy and feel that it si almost enough braking power for me. I never use my rear brake as stated above most of your braking power is in the front brakes.
If you have 2000 or newer fork lowers you can get as Brembo caliper and 11.8" rotor off of teh newer (08 and up) baggers for a great price but I like my Pm stuff. If you want a super clean and smooth caliper HHI is the option I usually get for my customers.
Pm and HHI calipers will utilize the stock size rotor which is 11.5".
I felel that brakes can be the difference between life and death, working brain or vegetable, broken leg or road rash. If none of that is important to you, get what looks good.
Choosing the right brake pad and rotor can make up for fewer pistons. The total piston area/volume is what matters for stopping force. I think multiple pistons can provide a better feel as do pad compositions.
Ask someone that races what they think. Except for the fact that you don't have to worry as much about heat fade, what they use will be a good place to look for starters.
C#
C#
