Hey guys. I recently put some V&H Straight Shot HS slip ons on my Deluxe. I've noticed a popping sound on deceleration. It doesn't do it at idle or when I'm on the throttle - only when I release to slow down. It's still riding smoothly and haven't had any problems. Have you guys experienced the same? Is it normal?
The bike is running fine. Pooping on decel is normal, and it did it with the stock pipes too, you just didn't hear it, *** the new pipes are louder. It won't hurt anything. Even if you tune to get rid of it, you'll want to keep a little pop to make sure you're running a tad rich. Popping DOES NOT mean you're running lean, it means you're a little rich. It's just unburned gasses in the exhaust that build up and ignite.
My 99 Softail Custom had popping in it when I went to drag pipes and K&N air cleaner. I went with bigger jets and that stopped it. So I would say if it is popping it is to lean. To much air and not enough gas.
