Projects fabricated for my 08 Deluxe
#41
#43
Thanks guys. Josewales you made me smile, that's good. The only thing I did was crank up the shocks. Most of the riding is two up so as soon as I got it I adjusted them. I haven't had any problems when we were loaded and out on trips. I am 5'8" and the better half is a lot shorter and neither of us weighs a lot so that probably helps. Pulling the trailer should be better than having all the weight on the bike on long trips also. Looking forward to getting some time to try it out on a little tour.
#46
#48
#49
I decided to change my stereo set up around,,,,,,just can't leave things alone. I moved my PBR300X4 amp to the downtubes on the frame. I couldn't find another place to put this amp. A machinist buddy milled me up a couple on ends for the amp out of aluminum. Between the two of us we got things drilled and tapped. The aluminum is siliconed where it's attached to the amp body. The aluminum blocks are hollowed out to allow room for the wires to the amp. I welded up some brackets for to clamp the amp to the downtubes and glued some rubber to them where they hold onto the frame. I drilled and tapped the aluminum blocks to bolt the brackets to.
Here is the amp mounted. Afted I mounted it I put a couple of layers of 1/2" weather strip so it totaled 1" thick at the face at the bottom of the amp. I put a line of grease on the weather strip and went for a gentle ride around the yard. I wanted to see if the fender would hit the weather strip and pick up some grease,,,,it did time to get back to the drafting table. plan "B" I made some brackets and attached them to the mounting ears on the fender which allowed me to move the fender down and ahead. More grease on the weather strip and another gentle ride,,,,no grease on the fender. Did a little more aggressive riding,,,,grease on the fender @#*!. On to plab "C" no one is going to like plan "C" I know I didn't. I cut off the mounting ears and drilled holes in the fender so I could lower it to where I hoped it would work. More grease and another ride this time I gould not get grease on the fender. I hated to do it but at least it worked.
I have four speakers two on the risers and two on the engine guards. I went to the Arctic Circle last summer and on the way home there was some metal fatigue on one of upper speakers. I got some new light housings and put the speakers in them, they are 4" two way. The bottom speakers are light housings but with 5 1/4" speakers. I had some 5 1/4" subwoofers in them last year but changed them out for 5 1/4" two ways. After about two rides I put the subwoffers back in. Heard much more of the music.
Sirius radio is nice to have.
I had the two way in when this pic was taken. The subs are yellow. The volume control is just to the left of the horn mounting bracket, but I want to change that later also.
I got the handle bar controls off a 98 Electra Glide Classic and put them on my bike. I want to use the volume control and the cruise if I put cruise on later. There is a forum brother seeing if he can come up with a way to make it work. That was fun changing all the wiring around, but that part is done and the bike started.
That's about it for the music,,,,this year anyway.
#50
I am adding this thread to my projects thread. I kept my stock Deluxe risers because I had things bolted to them that I wanted to keep there. I went with Bikini Beach bars. They feel good when riding, but you do have to look off to the left or right to use the mirrors. Much different than stock. I always have the windshield on but took it off for the pics. The leather bag and speakers I have mounted to the risers show up a lot more with the windshield off. They look cluttered compared to some of the great looking bikes with beach bars, but we like to tour with the things mounted on them. If anyone is thinking of Beach bars and wants to keep their risers these pics may help you some on how it'll look.
__________________
__________________
