cam bearing clean out TC88 ?
Old 01-26-2013 | 05:33 PM
8828alex's Avatar
8828alex
Default cam bearing clean out TC88 ?
SOMEONE SAID I NEED TO CLEAN OUT THE METAL SHAVINGS AROUND CAM BEARINGS OR CAM SHOES OR SOMETHING LIKE THAT DOES ANYONE KNOW ABOUT THIS AND HOW IS IT DONE BESIDES BRINGING IT TO DEALER
https://www.hdforums.com/forum/image.../icon_rtfm.gif
Old 01-26-2013 | 05:37 PM
QC's Avatar
QC
Are you changing out the cams? Give us an idea of what you're trying to accomplish.
Old 01-26-2013 | 06:01 PM
8828alex's Avatar
8828alex
i am not changing cams , someone told me that there is a build up of metal shavings around cam bearing or cam shoes ( not sure). this is supposed to be done around 30,000 miles on a TC88B motor. i have 52k on mine and was just wondering what exactly what needs to be done. if nobody can help i am going to call the dealership and inquire about(them ripping me off and doing a crap job) the details
thanks
Old 01-26-2013 | 06:07 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Check your cam chain tensioners. That is what you need to do and proceed from there.
Pfry (09-20-2024)
Old 01-26-2013 | 06:10 PM
QC's Avatar
QC
If the cam chain tensioners have not been replaced/upgraded, you should pop off the cover and take a look at them. What year bike are we talking about? The front tensioner is right there when you take off the cover, the back one you'll need a flashlight and small mirror to get a good look at. Just have to take off the front exhaust pipe to get at the screws for the cover. If you don't have a manual, I suggest you get one.
Old 01-26-2013 | 06:17 PM
8828alex's Avatar
8828alex
01 fatboy ,engine never gave me any problems and bike is semi retired at 52k. shold i be prepared to replace anything when i open it up for a check ?
Old 01-26-2013 | 06:22 PM
QC's Avatar
QC
The tensioners. Get a gasket. You won't lose hardly any oil. Just enough to make a mess. Just saw picks in another thread that showed minimal wear at 41,000. But your results may vary. If the bike has been well cared for, there may be nothing to be done. On the other hand....
Old 01-26-2013 | 06:33 PM
8828alex's Avatar
8828alex
this bike is ultra maintained and i will check it out over this winter.do you know if there are genuine HD upgraded cam tensioners for this bike?
Old 01-26-2013 | 06:38 PM
QC's Avatar
QC
Here is a link to the other thread I was talking about. Good info in it.
https://www.hdforums.com/forum/engin...r-upgrade.html
But, yes, there are upgraded tensioners and cam plates available. You could just replace your existing tensioners with stock replacements or upgrade to the later hydraulic system as I did last spring. Lots to investigate.
Old 01-26-2013 | 06:39 PM
8828alex's Avatar
8828alex
thanks for your help
Quick Reply: cam bearing clean out TC88 ?
