Internal cables?
As stated you def need a fat diameter set of bars. I've seen twist clutch setups to hide the clutch cable. I know they also sell and internal throttle cable setup. Definitely looks slick but I dont think I could get use to a twist clutch. If you know someone who does brakelines I cant see that being too difficult either. Check out the internal clutch and throttle setups online. If I remember correctly I took one look at the price and suddenly the cables being exposed didnt bother me anymore hahaha.
Yup they make there own kits. Top notch parts but this is where I priced em out before. Big bucks unless they came down in price. Its been a few years since I checked.
For clutch you have a few choices. You can get a low profile lever that is tighter to the bars and run a slimline clutch cable through the bars. You can try the exile or eurocomponents LH twist mech to activate the clutch but you will need to install an auto clutch or the exile kit with modified stock clutch or lastly you can do a foot clutch and switch to a jockey or tank shift.
On the right side you can do an internal twist throttle (there are several available) with a single cable and add a return spring on the throttle and for the hand brake you can get a goodridge double banjo bolt and plumb your front brake to the rear master with a proportioning valve on the back brake (this is how exile does it)
For switches see the Eurocomponents catalog for the low profile switches they have or go to a grip ace although the billet grip selection is limited unless you want to make a custom set.
You can do this in a 1in bar if you want with the eurocomponents stuff, for the thicker bars you have to go with the exile stuff and you may have to do some welding...Drew had to weld his internal throttle in due to complications with the 1in grip portions of his fat bars.
There may be other custom shops with components as well that others could recommend.
Here's what I did:
Exile internal throttle, welded in (can also use set screw)
Russell pro system brake line and fittings, run in bars
Grip Ace
Exile aluminum grips
Foot clutch / jockey shift
Hardest part was getting the throttle and brake line through my bars, but even that wasn't bad. Didn't need to add any return spring on the throttle body, it already has one that works just fine.
Grip Ace
[QUOTE=jreichart;10800158]Here's what I did:
Grip Ace
Hey brotha what foot clutch/jockey shift setup did u use?
Grip Ace
Thanks motown
