Harley Deuce 2001
Old 01-19-2013, 12:53 PM
radharley01's Avatar
radharley01
radharley01 is offline
Stage II
Default Harley Deuce 2001
Looking to change the 160 stock rear tire to a 180 ...any recommendations on extra parts , etc ... I need to make this possible ? Thanks
Old 01-19-2013, 06:13 PM
Wild-deuce's Avatar
Wild-deuce
Wild-deuce is offline
Only info for a 200 on 2001 Deuce
Old 01-19-2013, 07:09 PM
silent bob's Avatar
silent bob
silent bob is offline
Here is what you will need: http://vulcanworks.net/store_4/produ...&cat=90&page=1
You can fit a 180 tire on your stock 4.5" wide rear rim. So with this kit and a stock rim, you can do it.
Hope this helps.
Old 01-20-2013, 07:55 AM
oct1949's Avatar
oct1949
oct1949 is offline
Throughout the yrs in here a lot of other members have done the 180 HD kit..
While some others have just done a tire change.. With this one, seems I remember several other reporting that the tire is very close to the belt. Some tried it and it rubs occasionally.
Each tire maker tires in even the same size tire can and usually are different actual sizes.
U'll need to do some home work and some Google searches should net U the info U need.
Old 01-21-2013, 07:13 AM
94centennial's Avatar
94centennial
94centennial is offline
i have a 2000 Deuce. Last winter I installed a michelin 180 with no modifcations. it fits fine. the belt has about 3/16" clearance from the guard. it has never rubbed. i was going to use a Dremil tool to grind a little off the guard it I had an issue. HD dealer said i'd need a wide tire kit. It is not needed.
jeffsdeuce
01-13-2020 08:00 AM
fourhour
03-31-2014 12:30 PM
F.F.Knodey
02-06-2009 10:35 AM
lowperformance2
01-13-2009 12:33 PM
Crazy Canuck
11-10-2005 10:13 PM
Quick Reply: Harley Deuce 2001
