Dead Bike... well, kinda
#81
Maybe. Lol
Just not sure where to go from here. How would I know why the left signal is not working? I don't see anything wrong with the wiring that I can see.
I know it worked at one time so I am pretty sure its not a bad turn signal. I just don't understand electrical stuff enough to know how to figure out why its not work (or use tools to figure it out).
#82
#83
dennyo, the scoot is lookin sweeet....!
I do the same thing with the lights after disconnecting them entirely from the wiring system. First thing tho I make sure that with them disconnected that everything else is back to working order. Individually checking the lights is next. Heck I'd even go so far as hooking the old turns back up just to see if things worked alright with them on, but that's me. Just sounds like somewhere something is miswired or defective. I wonder if the equalizer is wired up correctly or if maybe its defective.
#84
I can't hook back up the old rear signals because I cut and spliced the old signal wires so I could use them for the new signals. I did think about plugging in the front signals and seeing what that does with and without the load equalizer.
#85
#86
Some do cut and splice wires but personally I do not. I even try and stay away from soldering wires if I can. Taking the time to pull wires sometimes saves your *** down the road. If done right (without nicking wires) you eliminate the chance of wires coming apart and other glitches you certainly do not want happening while you are out on the road.
#87
If I can't figure this out, I might need to take a ride to San Luis Obismpo. Lol
#88
#89
Right, there is no grease in it. But there hasn't been any rain and I haven't washed it since pulling the front turn signals. I did think about something like that... that's why I am going to pull the tank and installed the PRO ONE Turn Signal Bar.... it makes me feel better that something is plugged into that plug.
