Exhaust gaskets
Old 02-07-2007, 05:32 PM
WARG's Avatar
WARG
WARG is offline
Default RE: Exhaust gaskets
I went ahead and switched out my gaskets today with the SE gaskets. I guess its better to be on the safe side. My PCIII came in today, so now I just have to get it in to the tuner.
Old 02-07-2007, 05:49 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
ORIGINAL: twowheelsforever
Any tips or tricks to getting the new exhaust gaskets in? I've replaced several times on different bikes, and I always fight with getting the gaskets seated in the head without totally destroying them...
The orignals are a metal mesh,and best way to get them out is with needlenose pliers.
SE ones fit in snug, but not so tight that there is any difficulty getting them in. I believe they call it a crush fit. It expands as you torque the header against it.
tbroenick97's Avatar
tbroenick97
tbroenick97 is offline
Ive heard from a lot of knowledgable people not to worry about replacing them, however, they are crush gaskets and the deform when you torque them. With that in mind i always replace them and besides theyre relatively cheap.
Old 02-07-2007, 06:10 PM
Gerard's Avatar
Gerard
Gerard is offline
If I'm putting on an entirely new exhaust system I always use new gaskets. Since they are crush gaskets they are formed to the profile and size of the header flange that it was tightened against. I'm not sure why the amount of miles on a set of gaskets have to do with being able to re-use them. Installing a new system with old gaskets mayleave voids in the seal and could cause over-torqueing the flange nuts. Besides, like others have said...they're cheap.
Old 02-22-2007, 02:35 AM
FL DEUCE's Avatar
FL DEUCE
FL DEUCE is offline
I'm taking off my exhaust (Big Radius)to do some bolt replacements and I'll change the gasket. For $10 I don't want to risk having to take it apart again.
Old 02-22-2007, 02:42 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,908 Likes on 814 Posts
When I installed my V&H Straight Shots, I replaced the gaskets with the SE units. As others have said: cheap insurance.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
hollandhunter
02-24-2017 06:33 PM
sac130e
12-18-2015 02:59 PM
bulldog82098
07-10-2013 07:57 PM
dynarider
Exhaust System Topics
06-28-2007 04:37 PM
WARG
02-07-2007 06:44 PM
Quick Reply: Exhaust gaskets
