stage 2 103 pistons vs. stock 103 pistons
2012 HD Screamin' Eagle Parts catalog, Page 13;
http://www.harley-davidson.com/en_US..._SE12_Full.pdf
B. Screamin’ Eagle Big Bore Stage II Kit
for efi Models – 103 cubic inches*
the Stage II Big Bore Kit provides the parts you need to
increase the horsepower of your eFI-equipped model. the
kit increases the displacement of your twin Cam-equipped
model from 96 cubic inches (1584cc) to 103 cubic inches
(1690cc). Includes Stage II (Se-255) cams, Big Bore cylinders,
Big Bore flat top pistons, rings, pins, clips, and a Stage
I Air Cleaner Kit with one-piece back plate, integral breathers,
all mounting hardware, and gaskets.
The difference in dyno numbers would be the installation of the SE255 cams versus the stock cams in a 103.
Yes.
No. Like I said before, the increase in corrected compression is dictated by the cams used. In this case the stock intake valve on both a 96" and 103" factory cams close at 30* After Bottom Dead Center, or ABDC, for a corrected compression of 9.42:1.
Installing the SE255's, which have an intake valve close of 25*, in a stage II 96" engine, and the corrected compression goes to 9.55:1. This is with the stock head gasket thickness.
If you were looking for even more compression, then you start exploring milling the heads and thinner head gaskets.
