softail slim rear fender.
I think any darker vintage shade would look nice on your bike. Similar to something you might see on a 30-40s era auto. Wouldn't give you a ton of contrast but would give the bike a nice subtle vintage look. I'm leaning towards a deep burgundy myself.
i was thinking the same thing but right now i think i might just go back to black. luckily i have a buddy here that likes to paint and doesnt charge me much at his shop.
i have everything i need except for two brackets to support that rear fender. harley dropped the ball and ordered one side when clearly i need a set for the other side. weds they will have the parts.
ill show the before pictures when i have it all mounted.!
im pretty sure the fenders are the same however you would have to get an 08 or newer styled strut. the 07 and older inner struts are welded to the frame.
thanks man ill keep that in mind. I like the look on yours too. are you the one with the apes.? if so those are awesome. too bad i have short arms though haha.
OK, so I bought some Heritage struts for cheap on ebay. I wanted to see the difference between them and the slims. They are way different. I was hoping they would just be longer, but the bends are all different. If you swapped you wouldn't be able to use the Slim seat. I still might buy a cheap heritage fender and see if I can get it to work witth the slim struts.
yeah when i bought the struts and the fender i saw that problem with the seat. I am not going to cut the plastic on the seat either so i just bought the la pera barebones seat for a deluxe. good luck trying the slim struts id like to see what you come up with.
today i got all my parts needed to complete the install before i send it off to paint.
ran into some issues while installing.
everything mounted up well but a little bit of cutting might be required since i lowered the fender. clearance was good. the other problem i ran into was the seat. since i lowered the rear fender the holes don't line up and i have about a 1 inch gap. buzz kill...
anyways here is what i have so far. i'll have to hit the books and see what i can do.... might have to be a job that will wait. such a heartbreak.
