Inline Springer bars
Old 01-23-2013, 06:07 PM
FLYING_BURRITO_BROTHER's Avatar
FLYING_BURRITO_BROTHER is offline
NOT A MODERATOR
Received 20,424 Likes on 7,999 Posts
Mongo like!!!
Originally Posted by SprungDave
The ones on the right are the ones that can be mounted like this:
Old 01-23-2013, 06:30 PM
Bradley Jones's Avatar
Bradley Jones
Bradley Jones is offline
I wasn't a fan of whats out there so I cut the "ears" off my top clamp and made plugs to fit the fork tubes. Kinda hard to explain. Anyway I adapted it to accept most stock risers but the offset from riser to riser isnt like a factory harley handlebar clamp so I was forced to buy seperated risers instead of one piece risers. Once it was done I thought I was slick as **** but later found a thread where someone did the same exact thing hahaha. Keep in mind I have a repo of a factory 45 inline springer so there a good chance that other brand inlines won't have the internally threaded fork tubes. Ill try to find that site I stubbled apon where someone had beat me to the punch. Ill also post a link to a thread I posted but the pics arent the greatest. You can see in the side shot its a springer and the rear end shot it has regular non springer bars but thats about it sorry.
Old 01-23-2013, 06:36 PM
Bradley Jones
Heres my bar setup from a distance. Very easy mod that will allow the use of almost any bar as long as you match the risers to the handlebars. My issue was I wanted fatter bars but some bars are fat with a 1 inch diameter where it bolts to the risers. Well with the risers not offset like factory risers these types of bars were no good to me so I found full diameter 1.25 bars and modded 1.25 diameter risers. Of course things are easier if you stick with 1 inch bars.
https://www.hdforums.com/forum/softa...ore-after.html
Old 01-23-2013, 06:42 PM
Bradley Jones
Heres the website I found and whike looking for that it turns out these r actually made commercially now.
http://www.greasygringo.com/2012/05/...arly-springer/
http://www.phatperformanceparts.com/...vt-37-1016.htm
Old 01-24-2013, 04:58 PM
bc419's Avatar
bc419
bc419 is offline
Bradley- thanks for the explanation. This is very helpful. I've been searching for bars like these and this is a good solution.
Nice bike btw! Looks awesome!
Rick S
03-15-2019 10:22 AM
8 UP
Softail Parts
11
03-26-2013 06:47 PM
darksidebones
11-23-2009 03:58 PM
oldfooter
02-27-2007 04:47 AM
Mascman
10-15-2006 10:19 AM
Quick Reply: Inline Springer bars
