I replaced mine with some black plastic air line DOT tubing. I just removed the plastic splash gard to get to it. A good pair of side cutters for the clamps is key. I re installed with 1/4" hose clamps.
The splash gard must be the same as the inner fender, right?
Thanks guys. I just hope I can get the original clamps off without losing my cool.
Once you get ahold of them with pliers or sidecutters or whatever, give them a couple twists and they should break apart, or at least loosen up enough to get the hose off. A little patience pays off here, know going in that there is very little room to work.
