Help with Black Cases
11-24-2012, 01:49 PM
In an attempt to shiny-up the rocker boxes and outer primary cover, I inadvertently got some of the polish on the black inner primary cover and the black engine fins.
I have alredy washed the bike, but there is still a chalky-white residue embedded in the wrinkle finish. What can I do to remove it?
What do you all do to avoid getting polish on the cases? In hindsight I've thought of using painter's tape. Any other ideas?
Thanks
11-24-2012, 02:03 PM
Try S100 or WD40 either of them may shift it.
11-24-2012, 02:32 PM
Yep, what Magna said. S100 Engine Bright or WD40.
11-24-2012, 02:38 PM
PJ1 works as well. I avoid using the polish around the engine cases for that reason. I just use that Maguiars spray stuff on the parts you mentioned.
11-24-2012, 02:48 PM
Quote:
Originally Posted by
olongapo1
Yep and in the future tape off those areas with blue painters tape
11-24-2012, 03:21 PM
Did the same thing in several places on my first bike. Believe it or not, Magic Eraser took the chrome polish right off my wrinkle black engine block.
11-24-2012, 05:45 PM
11-24-2012, 05:48 PM
I needed this info last year! Eventually, mine burned off.
11-24-2012, 07:54 PM
Oh, and Magic Eraser works great for shining up those engine fin edges.
11-24-2012, 07:57 PM
Painters tape, if you must. I always polish by had for that reason.
