I removed my bags to clean up the rear end of the bike and saw how the exposed bolts will be left out in the open if I ever decide to ride without them. Is there anything to cover them up with?
If there not quick change you will have to decide whether you want them or not.
I removed mine and then removed the mounting stud and replaced it with a chrome button head cap screw to match the other ones on the fender brace.
+1 That's what I do when I remove the bags. If you go this route make sure you get a proper bolt with the right grip length. Too long, and you might have a tire/bolt interface problem.
My next purchase will be the HD detachable kit for sideplate and bags. The docking bolts are chrome and they also have chrome docking bolt covers. Until then, I don't remove the bags for that reason. I don't have the energy anymore to swap bolts every time. I guess it's a sign of getting old.
Beware of what fdb2007 noted. When installing the screws, reach behind the fender and make sure they aren't too long where they may contact the tire. I have cut screws to shorten them when necessary.
Ur dealer should have or can order these.
They have a strong Magnet to hold them on.
oct1949,
What size are the docking bolt covers you are using? Is your detachable system for the bags only or the bags and sissy bar? The chart in the 2013 P&A catalog is useless to determine which covers are needed for your setup.
I plan on getting the detachable sideplate and bags and want to buy the correct size covers. Most likely it would be the large ones.
