Battery-Alternator or ???
Old 11-19-2012 | 02:34 PM
Kenita's Avatar
Kenita
Default Battery-Alternator or ???
When starting my wife's 03 Heritage, you hit the starter switch, it cranks for a split second then "nothing" for another split second and then it cranks right up. It sounds like the starter hits a dead spot for a second before it catches. Battery is 10 months old but has been on a tender since new. Alternator is original. 30k plus miles on the clock. I don't have a volt meter to check the battery. Any ideas or is it me looking for problems that are'nt there?
Old 11-19-2012 | 02:37 PM
Hogpro's Avatar
Hogpro
Former Sponsor
It sounds like the battery to me. Just because it is kept on a tender it will not get the same charge that it will from being ridden. Every time I have had a battery do that it was the battery.
Old 11-19-2012 | 04:03 PM
IronAss's Avatar
IronAss
Ditto. Mine was doing the same thing shortly before the battery went titsup.
Old 11-19-2012 | 06:46 PM
Bone Doc's Avatar
Bone Doc
The battery must be properly tested. Simply putting a voltmeter across the terminals will not adequately test the battery. The voltage it puts out under a load ( ie: starting the bike) has to be checked.
Also, I agree with Hogpro. The fact that it has been on a tender has no bearing on whether the battery is good or bad.
Pull the battery. Any auto parts store can test it for you for free. Not that I'm suspicious in nature, but if the first place you have it checked tells you it's a good battery, I would go to another place for a "second opinion." If both agree, THEN the doctor's in!
Good luck.
Old 11-21-2012 | 07:42 PM
oct1949's Avatar
oct1949
It'd be nice if U put in how old the new battery is..
like 1yr old or 6yrs old....
Will Orr
04-04-2018 07:12 PM
jdunn01
2014-2023 Touring Models
08-08-2017 12:23 PM
Morris9982
12-31-2011 08:09 AM
_rero360_
09-13-2011 11:45 PM
dart451
08-04-2009 06:13 PM
Quick Reply: Battery-Alternator or ???
