1st change completed
Just got my Deuce a week and a half ago and it came with pipes that really didn't fit the look of the bike IMO , at least not what I wanted it to look like.
Picked up these Pythons up on ebay for $180.00, it looks so much better, they bark louder though . I'll ride it a little more before I decide if I want to try some smartpartz baffles.
Road a bit today and it sounds like a fuel management system will be in order sooner than I planed ,as it back fires and cackles when I decelerate , suspected that would be a side effect of the Pythons.
Grips , seat , tires (11yr old Dunlops ) , lower the rear ,sissy bar , pegs , bars / riser's , K&N air filter.
The bikes only got 3260mi so down the road maybe some mild cams.
Thanks , Yes I plan on few things over the winter. I found right & left peg bracket's plus the rear brake lever as a set on ebay @ $33.50 . The right side was bent by the PO , it appears it maybe got too close to the curb by the damage I can see. It went over in the grass I was told. By what I can see the bottom side of the pipes ,rear brake lever and section of the frame are road rashed and the R grip edge, basically repairs so far.
Tires are on the list , I think I will feel a difference. The rear has tried to get out from under me a couple of times not really pushing it, don't trust em. Not much riding left this season so I will have fresh rubber for spring.
I did look over the goose neck area as you suggested ,don't see anything , no marks or even paint cracks.
