My last 3 or 4 rides when I got back home I noticed a small stream of oil running down my oil tank starting just below my filler cap. I made sure the cap was tight & the next ride still doing it only there was 3 streams this time, one down the filler neck, 2 off to the right. I'm thinking, where the hell is the oil coming from if not from the filler cap. Yesterday, looking really good at my engine, I noticed a very slight bit of oil oil around the left rocker arm cover bolt on the rear cylinder. I'm thinking, is it leaking here & the wind is blowing it back on the tank? So, I was able to tightned it an eiqht turn or so, & guess what, after today's ride no more oil on the tank!
it happened to me too ...... but it was the dip stick cap , the rubber gasket was messed up replaced cap and no more oil on oil bag . But your info is good to know , Thx !!
