tank bolt won't budge help!
Old 10-08-2012, 06:44 AM
rgjujitsu's Avatar
rgjujitsu
rgjujitsu is offline
Default tank bolt won't budge help!
So I'm trying to remove my tank bolt that is near the seat so i can slide tank back but this thing will not budge. It's a t40, i tried screwdriver nothing, wrench nothing, neighbor brought over breaker bar still nothing? I'm a big strong dude and this thing will not move. Any advice?
Old 10-08-2012, 06:52 AM
Branner's Avatar
Branner
Branner is offline
Have you tried any of the penetrating lubes for stuck bolts? PB blaster, etc.. Might be worth a shot. If not, drill that sob out and replace it with new.
Old 10-08-2012, 07:13 AM
rgjujitsu's Avatar
rgjujitsu
Thanks I'll try it tonight!
Old 10-08-2012, 07:39 AM
phanowel's Avatar
phanowel
phanowel is offline
Heat it up.
Old 10-08-2012, 07:44 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,572 Likes on 2,890 Posts
Find a bigger, stronger dude and use some heat.
Old 10-08-2012, 08:11 AM
rgjujitsu's Avatar
rgjujitsu
What heat method would you use?
Old 10-08-2012, 08:57 AM
soft 02's Avatar
soft 02
soft 02 is offline
If I was worried about the paint I would use a soldering iron.
Old 10-08-2012, 09:08 AM
Silver Fox's Avatar
Silver Fox
Silver Fox is online now
Use an impact. If you can't get one try tapping on it when you are to loosen it. At times that helps.
Old 10-08-2012, 09:18 AM
oct1949's Avatar
oct1949
oct1949 is offline
Yeppers,, at work we used to use pent oil, then smack the bolt, it works sometimes. Also we used hammer Hand impact driver like below.
If U use impact gun make sure U hold down good, don't strip the head or U will have to use drill.
Old 10-08-2012, 12:08 PM
creed0423's Avatar
creed0423
creed0423 is offline
I usually just stick a long pipe on the end of the ratchet
Quick Reply: tank bolt won't budge help!
