My rear brakes are dragging causing abnormal heat. I just changed the rotor because it was a little warped. Rebuilt my caliper and master cylinder. I am at a loss...... Any ideas?
Today!!! I pulled both out, cleaned them and put them back in. I didn't change the seals. But I cleaned the caliper and rebuilt the master cylinder. Before putting the caliper back on I pushed 2-3 reservoirs of fluid through the brake line to flush any junk. Put the caliper on and bled the line. I'm not sure what else i should try.
Mine always drag a little plus if you put on a new rotor & pads let them wear some. I had a mechanic do my pads a few years ago & he didn't set the pad spacer right (spring like plate on the back of the pad) & I had a lot of drag & a blue rotor. Maybe yours isn't in properly.
Mine always drag a little plus if you put on a new rotor & pads let them wear some. I had a mechanic do my pads a few years ago & he didn't set the pad spacer right & I had a lot of drag & a blue rotor. Maybe yours isn't in properly.
Pad spacer? The spring that presses on the top of the pads.
