Are the pulley bolts like the rotor bolts where it's recommended you change them if you ever remove them instead of reusing them?
Yes, they are a one time use and should not be re-tourqed. Also, when you replace them its a good idea to mark them with a permenant marker so you know they haven't backed out at all and use a grade 8 bolt.
This is a wise idea. If you have ever had a bolt or 5 back out on you on the road you will do the same. Use red loctite on the pulley bolts. Here are torque specs for wheel stuff.
5/16-18 front rotor bolts 16-18 ft. lbs. 3/8-16 rear rotor bolts 23-27 ft. lbs. 7/16-14 pulley/sprocket bolts 65-70 ft. lbs. Hub assembly bolts 75-80 ft. lbs
I'll have to add the axle bolts to this as well. Back in a minute.
Happened to me before - I felt it pulled over tightened them (was only 5 miles from home) Got home parked it - replaced them all new grade 8 bolts and used red loctite. Then marked them.
