brake light problem
Guess I was lucky. Mine was a snap to change and the amount of break line fluid that actually comes out is so minimal that I didn't even bother with bleeding my rear break. It was literally like two drops of fluid. I just just had the new switch ready with some thread sealer on the threads to pop in one I got the stuck one out. Just a thought, have you considered cutting some of zip ties that hold your break line to the frame to see if you can pull it away from the frame to give you enough clearance?
Well, the exhaust isn't in the way. The switch is sandwiched right in between the frame and it's actually touching on the engine side. Can't even get an open end wrench on the damn thing (let alone turn it). No clearance for a socket either.. Cripes. Wondering if I need to take the whole bracket loose that the union/brake line is mounted to...
It looks like it's open, but you can't get any thing on it... (frame tube under and engine up top...) Frustrating. I can see it, I just can't get anything on it...
Anyway, I think I'll just have to loosen the bracket it's mounted to, to get it loose enough to get a socket and a swivel joint over it.
Benway...
The switch is bolted to the engine on my '09. I just had to replace mine yesterday after a hard brake when a large goose walked out in front of me at 50mph. The brake light was stuck on as the switch had failed. Mine looks different than your '07. See if the bracket is bolted to the engine. It should be one large Torx head bolt to remove and you can slide the bracket out and get a wrench on the switch.
There are a couple of zip-ties on the frame, you have to snip those off so you can pull the brake line out enough to work on it. You have to vacuum bleed the brake after the switch is replaced because there will be air in the hydraulic line. It's an easy job and the switch is about $21.00 at your local HD dealer.
Oh, and I missed that big assed goose- BTW
