Pipes/Exhaust removal
#31
Got a 10" and 6" 3/8" Wobble extension today from Oreilly Auto Parts (Lowe's and Ace Hardware had none). Worked like a charm! The Wobble extension is definitely the key. I had more problems just pulling the pipes out after unbolting everything than I did with actually just loosening up the bolts.
#33
Quick question... once I reinstall the pipes, do I need to replace the ring that is on the end of each pipe? It looks like a seal of some sort that goes behind the part that bolts on and holds the pipe. I just put these pipes on about 1000 miles ago and I am not sure if the indie that installed them replaced those... or if they need to be replaced in general. Thanks!
#34
#35
