Rear wheel offset
Rear wheel offset
So I installed my shotgun airshocks, and slammed the bike ('05 night train) to the ground. Come to find out, the left side of the fender was touching the tire while the right side had plenty of clearance. I did some research on this forum, and it seems some wheel offset is normal? That seems odd to me. If the rear wheel and the front wheel aren't perfectly aligned you would think that the handling would be affected. Of course I'm no engineer, so I can't be sure. Is this a softail thing? Any other manufacturers have rear wheel offset?
Here's a pic of my bike from the rear. You can clearly see the offset.
On my 05 train, both the front and rear are offset. Rear about .25" left and the front is about .25" right. Came that way from the factory. Front wasn't as noticeable as they offset the front fender mounts to center the fender over the tire. Supposedly it helps with weight distribution and straight line tracking. I think it was done mainly on the skinny front tire bikes.
