you will be fine it is barely leaking to get though the rest of the season it is seeping more than anything... you have to rub fork oil on the outside and inner side of the seals prior to installing them if not you run the risk of the seal binding durring install and leaking
ok good now i can put in extra heavy like i wanted to
